You can resolve this error by combining the individual variable references from all the libraries into the same arrays, create process variables (PV) for each variable and deploying it at once using Deploy Epics Server VI.
You can refer to the below diagram as one of the implementation examples.
Note: This image is a LabVIEW snippet, which includes LabVIEW code that you can reuse in your project.
To use a snippet, right-click the image, save it to your computer, and drag the file onto your LabVIEW diagram.
