Disabled C-State in BIOS of the PXIe-8840
Updated Jan 17, 2025
  • PXI-8840
  • PXIe-8840
The BIOS C-State setting may appear blank and default to [Enabled], which could make it seem unchangeable. This document will help you to disable the C-State feature in the BIOS of the PXIe-8840.
Disabled C-States in the BIOS.
1. Ensure the latest BIOS is installed.
2. Enter the BIOS by pressing <DEL> during boot.
3. Navigate to the Advanced menu.
4. Select System Profile Configuration.
5. Change the System Profile to Custom.
      • C-state may be greyed out if System Profile is set to OS Optimized
6. Change the C-state to Disabled.
      • Hyper-threading can be left Enabled.
7. Navigate to the Save & Exit menu.
8. Select Save and Restart.
