Filter Data Above Threshold in Systemlink Server
Updated Nov 27, 2023
  • SystemLink Server
SystemLink is a software platform that helps you manage, monitor, and control distributed systems across your enterprise. SystemLink File Service is a component of SystemLink that allows you to store and retrieve files from a central location. You can use SystemLink File Service to upload files from your SystemLink clients, such as TestStand, LabVIEW, or SystemLink Web Application, and download them to other clients or servers.
In this tutorial, it will show you how to filter and view the data of your file that is above the threshold level.
  1. Open the Data Navigation and find the file that you need to view the filter data. Then, press the Open File in the File Viewer.
  1. Go into the Explore tab and select the data that you need to view, for example Temperature_A. We can see now the graph of the Temperature_A data.
  1. To filter the data, you can go to the Filter tab and select the data that you need to filter. Then, insert the command for example x>22, this will filter the data above 22 degrees only.
