Unable to Access Datasocket URL Using LabVIEW 64-bit
Updated Nov 23, 2023
When I try to execute the DataSocket Select URL VI, it usually prompts me to select the URL like the picture below, but I couldn't find it in LabVIEW 64-bit. Why does this problem occur?
LabVIEW 64-bit does not support using DataSocket connections to an OPC server, so please use LabVIEW 32-bit.
