RFmx CDMA2000 Did Not Support Debug Session Mode
Updated Nov 23, 2023
  • RFmx
  • RFmx CDMA2000
RFmx software can support multiple communication standard , we can see the personalities in the software front panel after completed installing the drivers.
When you use RFmx to do some CDMA2000 testing , you found there was no selection for CDMA2000. But we can see the CDMA2000 option when you install the RFmx drivers.
Is there one solution for RFmx software front panel doing cdma2000 testing ?  If you wanted to enable debug session mode , how could you enable debug session for RFmx CDMA2000?
1.RFmx CDMA2000 had its software front panel ,which is a legacy panel , is not supported in instrument studio .
You can find the NI-RFmx CDMA2k Measurement Interactive Panel in start menu of computer.
2.The debug session mode feature is not supporting RFmx CDMA2000. The debug session mode only work in the common RFmx SFP (Instrument Studio).
NI  have a plan to add RFmx CDMA2000 into the instrument studio , but the feature is not completed now;
