Can I change the default settings of my GPIB-RS232?
Updated Nov 12, 2024
  • GPIB-RS232
I want to use my GPIB-RS232 in G-Mode, but I need a custom setting for the EOS (End of String) mode, since I cannot change this in the code. Can I store new default settings permanently on the GPIB-RS232?
It is not possible to store changed default settings on the GPIB-RS232. Values can be set while the device is powered on and will stay valid until it is powered off.
