When the "Run System Definition" option is selected, the VeriStand engine will immediately load and run the saved system definition file when it boots up, without needing to wait for a Gateway to deploy to it. Because of that, there is no way to enforce deployment order.
If the user wants to automate deployment and still be able to enforce the deployment order, you could look into using the VeriStand APIs to control deployment to the targets.
