SET-2010 Custom Device Channel and Relay Switches Behavior
Updated Feb 1, 2024
  • SET-2010
  • VeriStand
I am going to use SET-2010 hardware and have installed the SET-2010 EDS custom device. However, I have two questions as below:
  • There are 5 channels mentioned in the channel list - SET.Base.RefFaultCon, SET.Base.FefFaultSet0, SET.Base.RefFaultSet1, SET.Base.Ref0 and SET.Base.Ref1. The description of these signals is not clear. Is it possible to further explain the purpose of these VeriStand channels?
  • What is the default behavior of relay switches in SET-2010 and SET-2310? Are they normally open or normally closed?
The channels that referring about (SET.Base.RefFaultCon, SET.Base.RefFaultSet0, SET.Base.RefFaultSet1, SET.Base.Ref0 and SET.Base.Ref1) are used to set the relays on the SET-2010 for connecting the reference signals on the front I/O connector to the fault bus on the Rear I/O. For example, you might set those channels to connect J2REF4 to Fault Bus A.
2010 ref
All relays are default open on power-up unless the default state is changed in the topology file. If another startup state is desired, the topology file can be edited to add new topologies that will put certain relays in a closed state when the card boots up.
