NI-VISA Configuration Is Not Detected USB Port in Ubuntu
Updated Feb 8, 2024
  • NI-VISA
Other
  • Ubuntu
I am using Ubuntu. I can detect my USB port using the command prompt but the port is not detected by the NI-VISA configuration.
This could be the user privilege issue. Please try to open the NI-VISA configuration wizard using administrator privilege. By default, the NI-VISA driver development wizard executable(visaconf) can be found in /usr/bin. If you do not find the executable ensure you already install the NI-VISA driver and check the natinst-nivisa-visaconf.desktop file from /usr/share/applications to get the executable location.
