Real-Time Watchdog Configuration VI Causes System to Restart in LabVIEW Real-Time 2024
Updated Nov 9, 2023
  • LabVIEW 2024 Q1 Real-Time Module
I started using LabVIEW Real-Time Module 2024 and my system is now restarting. What changed?
Beginning in LabVIEW Real-Time Module 2024, startup applications using the LabVIEW Real-Time module Watchdog Configure.vi with the disable watchdog on VI exit boolean set to false and the reset system boolean set to true should expect their system to reboot upon a watchdog expiration. This is a change from previous behavior, where a system would not reboot in these conditions.
Note: if the timeout value for the Watchdog Configure.vi is set to <25 seconds, a system could enter an infinite reboot scenario requiring a reformat.
