Upon doing nearest neighbor interpolation using Linear Mapping Stairs using VB Script, below difference of DIAdem 2020 SP1 shows 55 and DIAdem 2021, DIAdem 2021 SP1 & DIAdem 2022 Q2 shows 12 occurs.
Figure 1: Result from DIAdem 2020 SP1
Figure 2: Result from DIAdem 2021, DIAdem 2021 SP1 & DIAdem 2022 Q2
Which of the Figure 1 and Figure 2 is the correct result?
If DIAdem 2021 and above is correct, is there any workaround to get the correct result for DIAdem 2020 SP1?
