I am using the
Spreadsheet String to Array Function and have a string array wired to the
delimiter (Tab) input terminal that includes an empty string as one of the elements. When I run the VI, it shows the following error message and cannot properly convert the spreadsheet string to an array.
LabVIEW:
Invalid input parameter. For example, if the input is a path, "?" or "@" or other characters not allowed by the OS may be included in the bus.
Top-level VI "xxx" stopped at "T2A" converting spreadsheet string to array (block diagram: xxx.vi).
