I am trying to transfer files from host PC to a Real Time target by using the WebDAV's Simple Put VI in LabVIEW as show as follow:
When I try to copy the files to the remote device I get the following error:
Error -124103 occurred at an unidentified location.
Possible reason (s):
LabVIEW: The requested resource does not support the specified DAV method. Ensure there is a WebDAV server installed on the host and enabled on the specified port. When communicating with LabVIEW Real-Time targets, specify/files as the URI prefix.
