Este contenido no está disponible en su idioma de su preferencia.
El contenido se mostrará en otro idioma disponible. Su navegador puede proporcionar una funcionalidad para ayudarle a traducir el texto.
Error -2147224709 Occurred When Using VCOM Toolkit in LabVIEW
Updated Oct 24, 2023
  • Vehicle Communication Toolkit
  • NI-XNET
I am using the LabVIEW APIs of VCOM to develop an application for CAN testing with an AUTOSAR XML file. The Get Signal Names - Base License.vi is used to get the signal list. But I get the following error:
The Get Signal Names - Base License.vi only supports dbc and ldf files rather than arxml files. If you want to use the arxml file for bus simulation, the Get Signal Names - Full License.vi should be added to your application. The Vehicle Communication Toolkit offers a base and a full option. The following table lists a comparison of features included in the Vehicle Communication Toolkit (Full) and (Base) versions.
