PXIe-5668 Have High Spurs In Low Frequency Bands
Updated Oct 23, 2023
  • PXIe-5668
When you used PXIe-5668 to measure one CW signal at frequency lower than 3.6GHz , you will see some spurs in the low frequency bands , like below picture :
When you measured the CW signal at high frequency bands ( higher than 3.6GHz) , you will not see the spurs;
Check the spec of PXIe-5668 , you will see below data :
So what you see is an expected result ,  why is there a big difference between lower frequency bands and higher frequency bands ?
Check the hardware diagram of PXIe-5668 , you will see below picture :
You will see there are two hardware paths for different frequency signal ; There is one YTF filter for the high frequency( over 3.6GHz)  , but there is no YTF filter for the signal which frequency lower than 3.6GHz ;  So you will see different result about spurs for different frequency signal;
