Usually, this happens when exists a modification or corruption error.llb
To solve this issue we can:
- You can replace the error.llb file with a copy of that file on another computer without the issue and with the same version of LabVIEW.
- You can find the error.llb file at the following path: C: \ Program Files (x86) \ National Instruments \ LabVIEW 20xx \ vi.lib \ Utility
