Auto Detection of 3rd Party cRIO modules shows modules as unsupported
Updated May 21, 2025
  • LabVIEW FPGA Module
  • NI CompactRIO
Other
  • cRIO-904x
  • cRIO-905x
I want to use a 3rd module in my CompactRIO 904x or 905x. When I use the auto-detection, I get the following error:
When using a different cRIO controller, like a 9030, everything works.
On the new DAQmx-enabled CompactRIO controllers (904x and 905x), the auto-detection for 3rd party modules is not implemented.
To still use the modules, you can manually add the modules, like described in Adding a New C Series Module to a cRIO Project in LabVIEW.
