Whenever I attempt to start Calibration Executive I get any of the following error descriptions:
- The TestStand Engine cannot be initialized.File format error. The file 'C:\ProgramData\National Instruments\TestStand 2013\Cfg\TestExec.ini' is not a configuration file. and after clicking this twice, the following is coming: Error -17500 occured at Exception occured in TSUI.IApplicationMgr: Cannor create TestStand Engine in UI_TEstStand - Set TestStand Application Window.vi->cex_GUI_Top-LevelVI.vi->cex_GUI_Launcher.vi
- Error -17500 occurred at Exception occured in TSUI.IApplicationMgr: Cannot create TestStand Engine in UI_TestStand -Set TestStand Application Window.vi->cex_GUI_Top-LevelVI.vi->cex_GUI_Launcher.vi
The error codes are undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
After clicking OK I get the following window:
How can I solve this issue?
