NI CAL-4353 Verification Procedure With LabVIEW
Updated Jul 21, 2021
  • CAL-4353
  • PXIe-4353
I am trying to calibrate a CAL-4353 and am unclear about how to open a NI-DAQmx Calibration Session on my device using LabVIEW. What does this entail and how can I get started?
Verification of a CAL-4353's operation involves initializing an external accessory calibration in LabVIEW and taking resistance measurements of the device's CJC terminals per the instructions in the CAL-4353 Calibration Procedure.
Note that calibration/verification of the CAL-4353 in Calibration Executive is currently not supported.
See the attached block diagram for an example of the programming flow for verifying a CAL-4353's specifications:CAL4353Calibration.png
