Upgrade VI to a Newer LabVIEW™ Version
Updated May 20, 2026
LabVIEW is forward compatible, meaning that you are able to open VIs from previous versions of LabVIEW in more recent versions. Upgrading to later versions of LabVIEW allows code reuse while also integrating the latest improvements.
This tutorial walks you through how to upgrade your LabVIEW files to a newer version of LabVIEW.
Considerations
Before upgrading your LabVIEW code to newer versions, take the following into account:
  • When upgrading code, there is no guarantee that LabVIEW code will run properly without editing.
  • If your project contains custom code or complex architectures, note that in newer LabVIEW versions, some VIs may appear broken. In such cases, you might need to rewrite portions of the code to ensure compatibility with the newer version.
  • If your LabVIEW files utilize APIs from LabVIEW modules, note that LabVIEW modules are only compatible with the version they are built for. For more information about compatibility, review the README file of each module.
  • For more information, please search and check the upgrade notes for the LabVIEW version you are trying to upgrade.
  • If you are upgrading code that was created before LabVIEW 6.0, see the Note on Upgrading from Legacy Versions of LabVIEW section below.
  • Read the Upgrading Your Version of LabVIEW help material for your version of LabVIEW. This will prepare you to detect and correct upgrade difficulties as efficiently as possible.
If you are in the process of upgrading your system and would like to ensure compatibility of your new software version with your existing hardware or OS, contact Sales by calling the number associated with Purchase and Quote on the NI - Contact Us page.
Upgrade LabVIEW Files
  1. Launch the version of LabVIEW you wish to upgrade your code.
  2. From the File menu, select Open… and navigate to the location of the file you wish to upgrade.
  3. Select OK to open your files.
  4. From the File menu, select Save As to save this newer version of your LabVIEW code.
    • Note: If you use Save instead of Save As, this will save over the original version of the code.
    • Code from various versions can exist alongside each other. The best practice is to keep the original version of your code while in the process of upgrading.
  5. [Suggested] Mass Compile your code to maintain links between VIs and subVIs. This will also check for any corrupted VIs. A single file or an entire directory can be selected for mass compilation and the items will be opened in the new version, saved, and then closed.
  6. Please consider that some libraries located in C:\Program Files\National Instruments\LabVIEW 20##\instr.lib could be located in C:\Program Files\NI\LVAddons\niidl\1\instr.lib for LabVIEW 2022Q3 or newer versions. For more details refer to the related links.
To open a VI created before LabVIEW 6 in LabVIEW 8.5 or later, you must first convert the VI to a LabVIEW version between 6 and 8.2.
  • In this situation, NI recommends upgrading to LabVIEW 8.2.1 as an intermediate version because it is the version of LabVIEW closest to the current.
  • Customers with active software subscription licenses or service agreements can access older versions of LabVIEW by contacting NI support.
Once you have upgraded to a version after 6.0, you can continue with the steps above.
Note on Upgrading from Legacy Versions of NI-DAQ
If your VIs uses legacy NI-DAQ functions, these will need to be replaced with the new NI-DAQmx functions. For a more detailed guide about the differences between the two data acquisition functions and recommendations for the migration visit: Transition from Traditional NI-DAQ (Legacy) to NI-DAQmx in LabVIEW .
