System Is Empty On NI Distributed System Manager
Updated Feb 10, 2025
  • cRIO-9066
  • Distributed System Manager
My Real-Time (RT) Target under Network Items shows up empty on the NI Distributed System Manager (NI DSM) when I click on "+" to expand it. However, I can connect to my RT target via Measurement & Automation Explorer (NI MAX) and LabVIEW.
How can I monitor my RT target via NI DSM?
To work around this behavior, try to add manually the RT target on the NI DSM under My Systems. To do this, follow the instructions below.
  1. Navigate to the Actions tab on the NI DSM window.
  2. Click Add System to My Systems...
3. A pop-up window will appear as shown below:
4. Here we have to write the IP address or hostname of the target
5. Click OK.
6. The RT target will appear under the "My Systems" with the expected information.
This behavior might be seen when connected via VPN as well.
