Error -200 When Programming Parallel Loads on RMX-4005
Updated May 1, 2025
  • RMX-4005
I get the error -1074000000 from the RMX Instrument Driver, which includes error -200 (Execution Error) from the device when setting up two RMX-4005 loads in parallel. The error seems to be related to the command LOAD:DEL 0.000000; as shown in the screenshot below. That happens even when I example VI NI RMX-400x Loads Parallel Load Modules.vi that comes with the driver. The equipment works fine when manually configured and the VIs works fine with a single load.
Error description
In order to fix that issue, please make sure the RMX firmware version is 2.17 or later. You can download version 2.17 from the attachments section.
The firmware update instructions can be found in the user manual.
