Error -63193 Occurred At an Unidentified Location When Deploying FPGA Code to a Linux RT CompactRIO Target
Updated Oct 5, 2025
I am trying to deploy FPGA code to a CompactRIO target running Linux Real-Time (RT). When attempting to deploy my bitfile through LabVIEW or the RIO Device Setup utility, I receive the error:
Failed to establish connection
Error -63193 occurred at an unidentified location
Possible reason(s):
The requested feature is not supported
How do I resolve this issue?
This error comes from an incorrect connection to the NI-RIO server on the CompactRIO. To solve this try on of the following steps:
  • If you are using the NI Linux RT System Images, ensure NI-RIO Server is installed on the CompactRIO through NI MAX, or Hardware Configuration Utility.
  • If you are using the legacy CompactRIO image, ensure that the NI-RIO Server (Legacy) is installed on the CompactRIO through NI MAX, or Hardware Configuration Utility.
  • The issue can be caused also by the software installed on the host PC. Make sure to install and properly activate the required software for your NI RT target. If the software is already installed, try a repair or a fresh install.
To manage software installed on your CompactRIO controller, please follow the articles below.
