Error 15 During Application Build in LabVIEW When Using Timestamp URL
Updated May 31, 2025
I’m trying to build an application from my source code in LabVIEW. When I’m trying to use a timestamp URL to digitally sign my application, I receive the following error message:
Error 15 occurred at CodeSignAPI.lvlib:Get Signing Error String.vi
Possible reason(s):
Error: The Timestamp Authority URL specified does not point to a valid Timestamp Authority server, or an unknown error occurred.
Complete call chain:
CodeSignAPI.lvlib:Sign with Certificate.vi
AB_Application.lvclass:PostBuild.vi
AB_Engine_Build.vi
AB_Build_Invoke.vi
AB_Build_Invoke.vi.ProxyCaller
I checked the specified timestamp URL multiple times and I’m sure I entered the correct address.
How should I resolve this problem?
This error occurs because LabVIEW Application Builder currently does not support SHA-256 timestamp certificate. Either use an SHA-1 timestamp or use the Microsoft SignTool after you built the application to apply the SHA-256 certificate.
