TestStand API to Monitor Sequence File Status
Updated Jul 9, 2021
  • TestStand
May I know how can I monitor my current sequence file's status? I would like to perform post processing with If statement depending on the current status of the sequence file after it has completed a series of steps.
You can use the following variable to monitor current sequence file status
ThisContext.RunState.Main.SequenceFailed
This variable will return boolean true once a fail occurred in the sequence file and return false if all steps pass.
