Consume Tens of MB When Running LabVIEW Application File (EXE) with Empty Coding
Updated Oct 15, 2021
I created a blank block diagram and front panel of LabVIEW project vi and build as application file. When running the blank exe program, I observed that it consuming around 70MB memory from task manager.
Is this expected behavior?
LabVIEW Runtime itself needs few tens of MB to run the application file even both block diagram and front panel are empty.
