The 'Array to Cluster' function in LabVIEW has a limitation where it can not change the data type for arrays larger than 256 elements.
However, it is still possible to convert large arrays into clusters using the 'Type Cast' function. In the snippet below, the data of the 300 element cluster is maintained as the data type is changed into a cluster.
![Snippet.png](/servlet/rtaImage?eid=ka03q0000012Aiz&feoid=00N0Z00000HEWRt&refid=0EM3q000001oX8O)
