Its My Hardware Use Hardware Timing or Software Timing in Flexlogger ?
Updated Jun 30, 2021
  • FlexLogger
I am using NI hardware with Flexlogger, when I set the sample rate its will use hardware timing or software timing ?
Unless it is explicitly stated that a subsystem is using software timing in Flexlogger, all other tasks are hardware timed.
An easy example would be to simulate a USB-6351 in NI-MAX, you will see the following where the first port of the digital IO uses the digital sample rate set by the user while the rest of the ports will be software timed.
