In order to use a DigiMetrix robotics toolkit or library for use in LabVIEW, you will first need to download the appropriate toolkit/library to your development PC. These toolkits can either be downloaded from NI's site, for example, the Robotics Toolkit for Visual Components, or can be downloaded through VI Package Manager by searching for "DigiMetrix" in the add-on browser. Once this is downloaded, follow the appropriate steps below depending on your target.
PC
To activate a DigiMetrix toolkit or library for use on your development PC:
- If LabVIEW is running, close it before moving to the next step.
- Reopen LabVIEW when logged in on an administrator account or by using the "Run as Administrator" Windows option.
- Open the Third Party Add-On Activation Wizard by going to Help -> Activate Add-Ons through the LabVIEW splash screen.
- Select the DigiMetrix robotics toolkit or library you're looking to activate, and select Activate.
- Select "Automatically activate through an Internet connection," enter the License ID and password you received via email when you purchased your toolkit or library, and activate your software.
- Alternatively, you can activate your software using the Web Browser option and obtain an activation code with your License ID and password by browsing to the link listed in the window.
Real-Time cRIO or PXI
To activate a DigiMetrix robotics toolkit or library, you'll need to send your contact information and licensing information to DigiMetrix support at support@digimetrix.com. DigiMetrix will be able to assist you with the activation of your toolkits/libraries on your remote target.
You should receive your activation email with your License ID and Password within a week of purchasing a DigiMetrix robotics toolkit or library through NI. If you don't receive this email, or need to request your License ID or password again, you should reach out to the LabVIEW Tools Network Team, who manages the activation data for DigiMetrix add-ons, at labviewtoolsnetwork@ni.com.
