Unable to Connect Buttons via Global Variables in LabVIEW
Updated Jun 7, 2023
I have a subVI that has Control Buttons on the Front Panel and I want to control them using Global References.
For that purpose, I have created a reference from a Button and created its corresponding Global Variable Usually,
I prefer to use Switch Until Released and Latch Until Released as Mechanical Actions, but when I press the buttons from a newly created VI, they remain pressed. How can I resolve this issue?
If you are using Global Variables with references, the mechanical actions Switch Until Released and Latch Until Released will not work properly.
Use instead the other 4 mechanical actions for buttons (Switch When Pressed, Switch When Released, Latch When Pressed, Latch When Released).
Right-click on a button, go to the Mechanical Action section, and select them from the options mentioned above:
