This example demonstrates how to read the overlays that are applied to an image, save the Region Of Interest (ROI) with an image, read its properties, and restore the ROI information from the image later.
You will require the following software to be able to run the example code:
- LabVIEW Base Development System 2012 (or compatible)
- NI Vision Development Module 2012 (or compatible)
- If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
