TestStand is Ignoring the User Privileges
Updated Dec 18, 2025
  • TestStand
  • I'm using a user.ini file to limit the privileges of certain accounts but they still have the privileges
  • The operators can edit the sequence
  • You can hitĀ the cancel button on the login and you will still be able to edit sequences
  • If you edit the users.ini file then you have to restart TestStand in order for it to take effect.
  • Verify that the Check User Privileges is enabled:
    • It is located at configure/ Station Options/ User Manager
