Adding NI_Excel.lvclass to The Project Hangs LabVIEW
Updated Jul 8, 2021
Other
Microsoft Office
I would like to create an application with Excel access. For this I add the NI_Excel.lvclass file to the project so that it is available in the build specification and it later ends up under source files in "Always included".
Adding it in to LabVIEW project: on My Computer, the Loading window appears and freezes.
It says following:
Compiling: 1 of 44
C:\Program Files (x86)\National Instruments\LabVIEW 2020\vi.lib\addons\_office\_exclsub.llb\Excel_Insert_Picture.vi
Search: <This part stays grayed out>
As soon as I click on something: (No Feedback) appears in the window title.
From then on LabVIEW hangs.
I have tried to follow LabVIEW help instructions described in Including Report Generation VIs in Stand-Alone Applications (Report Generation Toolkit) article, but it was impossible to verify all files and VIs because I couldn't open them.
Issue can be solved by repairing Microsoft Office. For that follow below instructions:
  1. On the Windows Start screen, type Control Panel.
  2. Click or tap Control Panel.
  3. Under Programs, click or tap Uninstall a program.
  4. Click or tap MicrosoftOffice 365, and then click or tap Change.
  5. Click or tap QuickRepair, and then click or tap Repair. You may have to restart your computer after the repair process is complete.
