PCI-DIO-96 Unable to Be Recognized by Traditional NI-DAQ (Legacy)
Updated Jun 14, 2021
  • PCI-DIO-96
  • Traditional NI-DAQ (Legacy)
I have installed compatible Traditional NI-DAQ (Legacy) on my computer to detect PCI-DIO-96 in NI MAX and able to detect without issues. But after installing NI-DAQmx in the same system, Traditional NI-DAQ (Legacy) unable to recognized PCI-DIO-96 in NI MAX.
Figure 1: Traditional NI-DAQ (Legacy) able to recognize PCI-DIO-96 in NI MAX without issues.
Figure 2: Traditional NI-DAQ (Legacy) unable to recognize PCI-DIO-96 after installing NI-DAQmx although device is detected in NI MAX.
To resolve this issues, you can try the method listed below:
  1. If you have recently installed new NI software, drivers, or hardware, restart your operating system (OS).
  2. Try install PCI-DIO-96 in different PCI slots.
  3. Reinstall/Repair Traditional NI-DAQ (Legacy) driver.
Additional Troubleshooting Suggestions:
  • Connect your PCI-DIO-96 to another computer. Make sure this computer has the correct drivers installed.
  • If you have another PCI-DIO-96 that is connecting correctly, try using it on this same computer to see if the issue persists with the computer or with the device.
  • Make sure you have the Devices and Interfaces section expanded.
