Selecting ECUTS Mass Interconnect Components and Tools
Updated Jun 1, 2021
System
  • ECUTS-16000
  • ECUTS-16001
  • I am servicing the ECU Test System's mass interconnect and require to know which is the correct tool to do so.
  • Which Virginia Panel Corporation components does the ECU Test System use?
  • Which mating module types should I select when configuring my Interchangeable Test Adapter (ITA)?
ECUTS Mass Interconnect (Receiver) Components
The ECU Test System's Mass Interconnect uses the following components and tools:
Mass Interconnect SlotsConnector TypeReceiver ComponentsReceiver Tools
Module *Module DescriptionContactContact DescriptionCrimperLocatorExtractor
J1, J18, J19, J20, J21, J23QuadraPaddle510150130192 Position, Loaded with Twin Female Contacts610138200QuadraPaddle, Twin Female  910110112
J2TriPaddle51010420616 Position, Dual TriPaddle / Mini Power610110177TriPaddle, 10 Amp, 14-18 AWG Crimp910101102910104146910110102
Mini Power610116112Mini Power, 8 AWG Solder  910112104
J3, J4, J5, J6, J7, J8QuadraPaddle510150115192 Position, Unloaded, For Crimped Contacts610138216QuadraPaddle, 22-28 AWG Crimp910101125 910110112
J9, J10, J16Mini Power51010412319 Position, Mini Power610116112Mini Power, 8 AWG Solder  910112104
J12, J14TriPaddle51010413696 Position, TriPaddle610110177TriPaddle , 10 Amp, 14-18 AWG Crimp910101102910104146910110102
J22Micro Power51010426750 Position, Micro Power / Micro Coax610142101Micro Power, 12-14 AWG Crimp910101102910104145910112123
Micro Coax7-362116525-036Micro Coax to SMA Plug, RG316, 36 in. Patchcord  910112123
7-362116526-036Micro Coax to BNC Plug, RG316, 36 in. Patchcord
7-362116527-036Micro Coax to SMB Plug, RG316, 36 in. Patchcord
J24TriPaddle51010420616 Position, Dual TriPaddle / Mini Power610110101TriPaddle, 7 Amp, 20-24 AWG Crimp910101103910104127910110102
Recommended ITA Components and Tools
NI recommends the following Virginia Panel Corporation components and tools to mate with the ECUTS mass interconnect slots:
Mass Interconnect SlotsConnector TypeITA ComponentsITA Tools
ModuleModule DescriptionContactContact DescriptionCrimperLocatorExtractor
J1, J3, J4, J5, J6, J7, J8, J18, J19, J20, J21, J23QuadraPaddle510151121192 Position, Right Angle for PCB, 510151107 and 510109316610138115QuadraPaddle, Round Post  910110111
510151105192 Position, Unloaded610138109QuadraPaddle, 22-24 AWG910101103910104140
610138112QuadraPaddle, 26-30 AWG
610138122QuadraPaddle, Square Post
610138123QuadraPaddle, PCB Pin910113106
510151124192 Position, Loaded with Square Posts610138122QuadraPaddle, Square Post910110111
J2, J24TriPaddle51010817816 Position, Dual TriPaddle / Mini Power610110108TriPaddle, 20-24 AWG910101103910104107910110102
610110113TriPaddle, Square Post
610110129TriPaddle, 14-18 AWG910101102910104118
610110169TriPaddle, 26-28 AWG910101103910104107
Mini Power610115124Mini Power, 50 micron AU  910112104
610115125Mini Power, 30 micron AU
J9, J10, J16Mini Power51010811519 Position, Mini Power610115124Mini Power, 50 micron AU  910112104
J12, J14TriPaddle51010812596 Position, Right Angle for PCB
51010812696 Position, Straight610110108TriPaddle, 20-24 AWG910101103910104107910110102
J22Micro Power51010826250 Position, Micro Power / Micro Coax610143101Micro Power, 12-14 AWG910101102910104144910112123
Micro Coax610141101Micro Coax, RG316 (use Crimper 910101132)  910112123
610141102Micro Coax, RG178 (use Crimper 910101131)
A 3/32 inch Allen Wrench required to remove modules from the receiver
