Can I Use Slot 10 of the PXIe-1092 for My PXIe Card?
Updated Jun 3, 2021
  • PXIe-1092
Other
  • PXIe-1092
  • PXIe-1486
  • PXIe-1487
  • PXIe-5841
The PXIe-1092 has a system expansion slot in slot 10 called the peripheral expansion slot. This has a black connector to the backplane of the chassis, which is different from the other slots.
  • Can a regular single slot PXIe card be placed in slot 10?
  • Can a multi-slot module use slot 10?
This slot is to allow extra space in the chassis for multiple-slot modules to be placed in slot 9, for example:
  • PXIe-1486 or PXIe-1487
  • PXIe-5841
The connector provides access to the power lanes and from Revision B onwards, some CLK signals for the PXIe-5841.
You cannot connect a regular 1-slot card into slot 10, as it does not have the full set of connections to the backplane and will not operate correctly.
More information is available in the PXIe-1092 User Guide in the Peripheral Expansion Slot section.
