VeriStand Error 1136 When Configuring System Definition File
Updated Jul 25, 2022
  • VeriStand
  • Error 1136 is displayed whenever a item is selected in the DAQ tree of the system definition file for the first time.
  • The system definition file deploys correctly to the target and operates as expected.
Error 1136 occurred at Property Node (arg 1) in DAQ.lvlib:Set Automatic Chassis HW Master.vi->DAQ.lvlib:AI Section Init.vi->DAQ.lvlib:AI Section.vi
Possible reason(s):
LabVIEW: (Hex 0x470) You wired an invalid item tag to a tree control property or method.
Error 1136 VeriStand 2019 R2
This was a known issue for VeriStand 2019 R2, which is purely cosmetic. The following will stop the pop-ups appearing:
  • Expand the FPGA tree in the system definition file.
