이 내용은 고객님의 설정 언어로 확인할 수 없습니다
Determining Compatibility for Migrating from PharLap to Linux RT
Updated Aug 7, 2023
  • PXI Controller
  • LabVIEW Real-Time Module
The migration from NI Phar Lap ETS to NI Linux Real-Time means migrating your application from one operating system to another which takes several steps. This article is part of a series on migration to NI Linux RT:
  1. Determine compatibility
  2. Provision your PXI controller
  3. Install software
  4. Migrate Phar Lap application to NI Linux RT
Before starting the migration process, you will need to confirm that your PXI controller and PXI hardware is supported by the NI Linux RT operating system and the LabVIEW Real-Time Module. This document addresses compatibility in your system so you can continue migrating.
  1. Determine your PXI controller and NI Linux RT compatibility:
    1. Confirm that your PXI controller is supported on NI Linux RT.
    2. Review overall PharLap and LinuxRT controller support.
  2. Determine your PXI hardware and driver compatibility:
    1. Confirm that your PXI chassis and hardware is supported on NI Linux RT.
    2. Confirm that your PXI driver software is supported on the NI Linux RT .
  3. Determine your LabVIEW Real-Time Module compatibility.
Next Steps
After determining your system components are compatible, you can provision your controller to NI Linux RT.
