The migration from NI Phar Lap ETS to NI Linux Real-Time means migrating your application from one operating system to another which takes several steps. This article is part of a series on migration to NI Linux RT:
	Determine compatibility
	Provision your PXI controller
	Install software
	Migrate Phar Lap application to NI Linux RT
Before starting the migration process, you will need to confirm that your PXI controller and PXI hardware is supported by the NI Linux RT operating system and the LabVIEW Real-Time Module. This document addresses compatibility in your system so you can continue migrating.
