Archived:Display Custom Font in WebVI Without Internet Access
Updated Oct 20, 2022
  • LabVIEW NXG Web Module
I have gone through the knowledgebase article, Display Custom Font in LabVIEW NXG Web Module. It is the feature I need but my server is a company internal server. It does not have internet access. May I know how can I display the custom font in my webVI without internet access?
This article will explain how to display custom font in webVI without internet access using similar example from Display Custom Font in LabVIEW NXG Web Module.
To display Code 39 barcodes without internet access, there will be some changes in the steps mentioned in Display Custom Font in LabVIEW NXG Web Module:
  • Download and install the custom font on your server hosting the webVI. In this example, download Libre Barcode 39 offered by Google Fonts and install it as illustrated by images below. download custom font install
  • Remove the following link tag from your HTML source. You might have a different line number.remove script
After completing all the steps mentioned in Display Custom Font in LabVIEW NXG Web Module with the above-mentioned modification, you should be able to display the custom font on your server even without internet access.
