Where Is the Ground Lug for the Screw Terminal TB-9212?
Updated Oct 4, 2022
  • NI-9212
  • TB-9212
Other
The getting started guide indicates that I should connect my shielded thermocouple to the ground lug. Where is the ground lug of the TB 9212?
The screw indicated on the diagram below is the grounding lug. It is connected to chassis ground.
