Loading ASAM ODS Database values in DIAdem generates “NOVALUE” fields.
Updated Jul 17, 2026
  • DIAdem
  • ASAM e.V. DataPlugin for AOP5
Other
I am using DIAdem 2020 SP1 to load ASAM ODS Database values considering the following structure:
- AOTest
- AOSubtest
- AOMeasurement
- AOSubmatrix (1)
- AOSubmatrix (2)
- AOSubmatrix (3)
- AOSubmatrix (4)
However, DIAdem automatically selects all AO Submatrices, which presumably leads to an undesirable mix-up of the channels. As a result, the data is displayed as 'NONVALUE' in DIAdem VIEW.
I am interested in a solution that, for example, only selects a particular Submatrix (e.g. AOSubmatrix (2)) to avoid this issue.
Search and run the following VBScript in DIAdem SCRIPT: Ni_ods2dia_install.vbs
You can find it under this directory:
C:\Program Files\National Instruments\DIAdem 20XX\Libr\Documents\Utils\ODS\ni_ods2dia
After the script is executed, the option “Load ODS Data” will be enabled in
Context Menu
and Drag and Drop
As a result, the submatrices will be loaded in groups by using the option “Load ODS Data”
If you do not want these "NOVALUES" you should load the submatrices and do it without the value matrix.
