Disable TestStand Sequence Analyzer Built-In Rules
Updated Feb 10, 2025
  • TestStand
I would like to know how to disable some of the TestStand Sequence Analyzer built-in rules.
To disable a built-in rule, you can go to Debug » Sequence Analyzer » Current Sequence Analyzer Project, and uncheck the rules you want. For example, if you want to turn off checking for absolute paths, you can uncheck the Avoid using absolute paths item.
