Customize User Interface of TestExec.exe
Updated Apr 14, 2021
I am using TestExec.exe found in C:\Program Files (x86)\National Instruments\TestStand 2020\UserInterfaces\Full-Featured\LabVIEW\Source Code as the primary user interface to display execution of my sequence files with batch process model.
May I know can I customize the user interface of TestExec.exe to suit my project requirement?
Yes. User interface of TestExec.exe found in C:\Program Files (x86)\National Instruments\TestStand 2020\UserInterfaces\Full-Featured\LabVIEW\Source Code can be modified according to user needs.
Modification can be done in Build Script.lvproj which located in the same directory as TestExec.exe.
