NI System Configuration API VIs Are Broken
Updated Mar 28, 2022
  • System Configuration
Some of the NI System Configuration API VIs (Find Hardware VI, Initialize Session VI, etc.) are showing up with a broken run arrow as seen in the following picture.
Try following the steps below to resolve the issues with the broken NI System Configuration API VIs.
  • Mass compile the NI System Configuration API VIs using the following directory as the Directory to compile parameter in the Mass Compile dialog box: C:\Program Files\National Instruments\<LabVIEW 20xx>\vi.lib\nisyscfg.
