sbRIO Hangs With Custom CLIP Definition Under RMC
Updated Apr 27, 2023
  • sbRIO-9629
  • sbRIO-9629 XC RMC Bundle
  • LabVIEW Real-Time Module
  • LabVIEW FPGA Module
I used the sbRIO CLIP Generator to create a custom CLIP definition under the RIO Mezzanine Card for the sbRIO-9629. When I try to deploy a simple Flash LED code to the FPGA, it hangs and disconnects the board. Why is this happening?
When creating a CLIP definition under the sbRIO's Mezzanine Card make sure that all the pins are defined as the same I/O Standard. If not all the pins are defined as the same type I/O Standard, the target will hang and disconnect.
For example, for LVCMOS pins:
The same applies when using LVDS_25, LVTTL, or other I/O Standards.
The sbRIO CLIP Generator program will warn for incorrect pin configurations. Please pay special attention to these warnings.
