Access LabVIEW Web Service Application From Different Subnet
Updated May 17, 2021
I have deployed a web service using LabVIEW. I am able to access the web service from other machines within the same local network but other machines from different subnet are unable to access it.
What should I do in order to enable my machines from different subnet to access the web service?
Port forward is required in order to access the web service application from other subnets. Kindly approach your IT department to accomplish port forward for your web service application.
