LabVIEW Front Panel Boolean Button Size Change When Run As Executable
Updated May 17, 2021
The button on my front panel set to 15x15 in the properties. After build to executables (.exe), the size of the button changed. The size is maintain when run as VI.
This is caused by the text inside boolean button. The button size will resize according to the text inside the boolean button even when you already uncheck Show Boolean Text.
In order to prevent resizing happening, empty the On text box and Off text box, uncheck Lock text in center and Show Boolean text before building executable as below.
