How can I change the widths of all cells within a multi-column listbox or table simultaneously?
Hold down the shift-key while adjusting the cell width to simultaneously adjust the widths of all cells within the multi column listbox or table.
The row height can be set in the same way after unchecking the right-click option "Autosize Row Height".
A valid service agreement may be required, and support options vary by country.
