When the software is installed using the default Base System Image (Linux RT System Image 20.5) as the image below shows System Link and TensorFlow is installed per default and both packages include python libraries or services. For avoiding to install those libraries you can select the Custom Software Installation process and uncheck TensorFlow and System Link.
